Since I bought the Ortur Master 3 I have always had problems with USB communication, it starts the work and leaves it unfinished [MSG:34:USB SERIAL STREAM DISCONNECTED] I chose to continue using the WIFI and it almost always finishes the complete work, my situation Now the (set origin) + (set clear) buttons do not appear in the window (move). I set the default Layout and the (set origin) does not appear. I hit Restart and it still does not appear. What experience have you had? !
Check that your device is actually set for “GRBL”. Push Devices button in Laser window, then click once on the name of your device. What does it show at the bottom left of the Devices window?
