Lightburn 1.5: Where is the Save as RD File command?
Using HP Pavilion laptop with Windows 11 Home
OMTech - Ruida
On my machine, the USB connection is messed up. I have to save to a USB drive and then plug it into the machine.
In version 1.3 of Lightburn, the Save as RD File was on the File menu. I updated to version 1.5 and can no longer find Save As RD File. I have Google searched, searched the forums, and watched YouTube videos. Please, where did this command go?
It should be in the Laser panel, typically bottom right of your screen. ‘Save RD file’
Thank you for your prompt answer! I’ve uploaded a screenshot of what my Laser panel looks like in version 1.5. I had read that the Save RD File was there, but it is not in my Laser panel. I cannot connect my device via USB, but I have been using a USB drive to plug into the machine with version 1.3.
Is there another place to find this command or some advanced option where I can add it to the File menu?
You first need to configure a Ruida based device and select that in the Device pull-down for that option to be available. LightBurn uses the device selection to subsequently determine what other features to show on-screen.
