Hello,
Sins the version 1.5x i have problem with my switching between the Fiber and Diode laser
The diod setting in the files are right.
when the diod is the default laser it is keeping the settings that i change at that moment
and after opening its still ok, BUT
but i normaly have the fiber (Mopa M7) as my default laser.
with those settings no problem but select my diod and open the the diod file the layer setting are wrong again.
looks like a convetion problem from mm/s to the diode mm/m perhaps ??
Are there more people with fiber and diod have same problem ?
AND array serial number not aligning to center object?
Regards
Edwin
XLlaserdesign
