Lightburn 1.7.01 dxf export
Is there any bug in dxf export? I exported the project from Lightburn to dxf. When I want to import this dxf file into Deepnest, the program (Deepnest) freezes.
Bug locations:
  1. User drawing
  2. Deepnest
  3. Lightburn
Did this exact same drawing export and import into Deepnest with LB 1.6.03? Are all your objects a closes path? That looks like it might be a Deepnest requirement.
Upload your Lightburn file, if allowed, and we will see if it behaves in other software. You might look at the DXF in some other software.
Problem solved, you gave me the idea to check open shapes. After I fixed the open shapes, deepnest works as it should.
