3-Native Spirits Box Front Keeper Panels.lbrn2 (13.9 KB)
Falcon 2 20W Laser
When running the attached file, I attempt to frame and the laser moves to the proper point in the X direction then goes all the way in the Y direction to the stops and errors out.
I had a framing offset for my laser pointer set and turned it off and it still happened.
I have three other similar files with a slightly larger framing area all work fine. Is this file corrupted somehow?
Follow up.
Apparently the file was corrupted somehow. I created a new file and copied/pasted the two objects over to it and it frames properly now.
For some reason I couldn’t see that.
I recreated the project and it worked fine.
thank you!
