LightBurn 2.1 Ortur Rotary / start point issue, plus camera trouble
I have the same issue with this update. I simply just setup my Ortur Rotary tool like always. according to how to burn where you want it to start you use Current Position for your job origin. This way I can be exactly center of the Yeti logo with whatever I am burning and its center on that logo when finished. I ruined a tumbler last night because on starting my burn where I set the laser, it gives the error that it will burn out of bounds. other times it just starts to burn almost two inches further from the actual start point. I was up all night trying to fix this to no avail. I need to fix this so I can use my laser. I have a camera installed and your camera setup software is screwed up. When I go to do the alignment the burn you are suppose to do with the the numbers only goes to about a quarter of its size even when set to burn full size. So now I can’t setup the camera for this new update. any help would be appreciated. I loved this software and now it’s no good to me.
You said “I have the same issue” and then proceeded to describe a completely different issue, on completely different hardware.
I’m going to move your post to be it’s own post so we can keep track of things easier.
I meant the same issue as in after the update my software doesn’t work properly. But thank you for responding so quickly. I don’t use my Atomstack S10 Pro for a business. it is just for hobby burning and doing free things for my Scout Troop. Any help would be fantastic.
When you use ‘Current Position’ for starting on the rotary, is the software in ‘Rotary Mode’? And where do you have the ‘Job Origin’ dot set to?
Yes, its set in the Rotary mode, Current Position Job Origin is set as the middle dot on the left. The green dot/square shows up on my project in the middle as the start point. I have been doing it this way ever since I have had the software.
I then manually have to move the laser to the position where I want to start the burn. When I start it the laser moves forward about 1 to 2 inches to far from where I wanted it to start. it ruined the tumbler because the top burn was now way out of the boundary and burning air. I then used this ruined tumbler on all sides to experiment on. I even moved the laser lower hoping to compensate for the 1 to 2 inch movement and it still moved to that first spot. I was up all night trying to figure this out.
Can you show a picture of what the file looks like in LightBurn? (take a screenshot so I can see it)
