Lightburn and Ortur Laser Master keeps crashing
Hello,
I have a few issues with my Ortur Laser Master and Lightburn.
When it works it’s great but my goodness I have to reboot the machine or restart the program so many times it’s insane.
I press a direction to move? The machine lose its connection and freeze.
I want to do a Frame? Lightburn crashes.
It’s getting very frustrating because I bought the program and I don’t want to use GRBL, too limited.
Is anyone having issues or it’s just me and I’m just not lucky?
LightBurn crashes when you frame? Or does the device go “Busy” and stop talking to you? If it’s the second thing, most likely you’re set in the wrong origin mode, hitting the limits of the machine and it’s triggering an ALARM:2 (out of bounds). Is that what’s happening? If so, change the ‘Start From’ setting in the Laser window to ‘Absolute Coords’ and read here: https://lightburnsoftware.github.io/NewDocs/CoordinatesOrigin.html
Ciao, non sei l’unico ho lo stesso problema e non riesco a risolverlo con laser grbl funziona bene per caso hai risolto il problema?
Hi, you are not the only one I have the same problem and I cannot solve it with laser grbl works well by chance have you solved the problem?
