as i can’t find anything about lightburn on raspberry, i presume it is not possible ?
You are correct, the rPi is not currently supported to rum LightBurn. But you could save the Gcode from lightburn if using the Gcode version, then stream it from an rPi to your controller in the laser.
thank you. the purpose is to make an inexpensive laser cutting chain for my airplane modeling club. I will use that :
