Lightburn bridge setup giving me "TypeError: expect bytes or str, got list"
When I plugin the “pi” the setup runs but stops tells me the pi default password needs to be changed then I get a Traceback and a typeError :“expect bytes or str, got list”
here is the full trackeback.
it is a pi3
What have you done so far to get to this point?
this was a bad response. please see blow
o to get this this point. I just did a burn to the SD card. plugged the card in. and turned to power on to the pi. the pi comes up with its color screen. then jumps in to doing logs of installs and updates and the like. you know. black screen. lots of text flying by. the last [OK] was Started update UTMP about System Runlevel Changes. After that I got change pw and then the Traceback
I never see a OS or the APP running
Where did you get the image and what did you use to flash the image? Are you using the instructions included here?
Advanced LightBurn Bridge Setup - LightBurn Software Documentation
Have you checked to see if a WiFi AP from the Bridge is visible on your computer?
