Lightburn caint find my laser
i use gsender with another programe and my laser works fine , now using lightburn it woint conect to lightburn
strong text
Try using the manual method for creating the Device Type. I am guessing the Longmill is a GRBL based controller, so select GRBL without any other letters.
i do use the manual to find my laser . is there a way to manually load the laser
Yes, just do not search for it, add it manually. Connection type “USB”. Then you can select the COM port once LB window is opened in the laser window.
