JUST
(JUST)
January 15, 2022, 7:39am
#1
The camera selection help tool has narrowed things down. 8mp with 1.33 aspect. The mounting height is 31". Technically both the 75 and 120 meet the minimum mounting height of 13.3" and 23.3". That’s quite a difference in viewing angles so I figured I’d post for some advice.
edit:
Does the camera plug to the USB of a Bridge? edit: I see that it currently does not.
JUST
(JUST)
January 16, 2022, 6:47am
#3
Thanks. Input on the viewing angle?
jkwilborn
(Jack Wilborn)
January 16, 2022, 1:32pm
#4
I have this one on mine…
8MP 70° Wide Angle Lens USB Camera Module 3264*2448 w/IMX179
Everything calibrates OK. It is mounted at 23.5"
I have it going through the Lightburn Pi via OBS and see it in Lightburn. Never had one directly connected, so can’t advise you.
I know the software is being worked on but are their plans to make it the most perfect solution available by having camera integration?
I setup my LightBurn Bridge up today and it’s brilliant, the setup is fantastically simply and the functionality is perfect. Thank you for the hard work and I know I’m being greedy but as a Mac user it would be perfection with camera integration
Do I need to send beer or coffee???
As you can see the 70° seems plenty wide on my machine.
Good luck
JUST
(JUST)
January 18, 2022, 6:50am
#5
Is that Dilbert?
If you had to mount your camera 8" higher do you think you’d still prefer 70?
jkwilborn
(Jack Wilborn)
January 18, 2022, 3:06pm
#6
Didn’t say I preferred it. Just that the software appears to be very forgiving in this area.
If all is as it appears, which is rare, I would probably go down to a 50°, but it’s just a guess. I have more than what I need.
Mine is also a smaller machine, 3050
system
(system)
closed
February 17, 2022, 9:51pm
#8
