LightBurn changes the window layout when the PC restarts
Every morning when I start my PC, the window layout on the right-hand side is different. I want to see “Laser” and “Layers” nothing else. If I enable “Laser” and “Layers” now, they are disabled again when I start my PC the next day, replaced by other windows I don’t want to see. Unfortunately, support hasn’t been able to help me.
I find this very difficult to accept.
Sometimes Windows does not behave the way we want. In that pull-down list, uncheck everything except the Laser and Cuts / Layers lines. Ensure that is the layout you want.
Go to File, Preferences, Export Preferences and save that with an appropriate time stamp. Now go to File, Exit and close Lightburn. This is the proper way (EXIT) to close down a Windows application.
N O W . . . Open Lightburn and see if your layout is the same as when you closed it. If not, then Lightburn support (@JohnJohn) has something to work with.
Radical Acceptance is key to troubleshooting. It took me several attempts to learn this the hard way. It was worth it.
If something is misbehaving and if one has been attempting to resolve the issue for far too long, one must be willing to accept that one of the initial assumptions is likely incorrect.
I find that Win 11 occasionally behaves in an unanticipated or unwanted way - particularly notoriously with OneDrive and settings files.
One of the things about LightBurn that I was literally overjoyed to learn about early on, was that it saves all of the users ‘Preferences’ (including the layout) in a file with the extension .lbprefs with the date as part of the filename. Every time the user makes a change to the .lbprefs file, a new version is saved.
It will save up to the last 50 most recent versions of the .lbprefs file on the local drive.
This allows anyone who has fumbled a setting to roll back several months if needed and pull up the previous preferences that were working properly.
I have the heartwarming sense that someone on the Dev team may have been chasing an issue with a setting and had enough of that nonsense and built this extremely robust recovery method for user prefrences in the lbprefs file.
Troubleshooting Test Set #1 for lbprefs files:
  • Open a Windows Explorer tab
    • This allows you to see the files on the computer and what the files are named.
    • Yes, I’m being excessively precise here to the point of being pedantic.
    • I’m doing this because I think one of the initial assumptions may be wrong and I want to help capture which assumption might be wrong.
    • Capturing an inaccurate assumption benefits everyone.
    • This is my second favourite thing about my job. :slight_smile:
  • Change the address in the address bar until it is looking at the local drive
    • This is usually the C: Drive
  • Enter the name of the file extension lbprefs into the search bar beside the address bar.
  • Press the Enter key.
    • It’s probably not necessary to press the Enter key but I like to confirm that I’ve stopped searching for incomplete file name extensions.
  • I expect your Win 11 computer to find several copies of the lbprefs file with different dates in the filename.
  • Please upload a screenshot of the list of files, including the directory.
    • I’m interested in knowing that the files are there and which directory they’re in.
    • If the directory is the same for all the lbprefs files, only the last few files are necessary.
  • Please also upload a copy of one of your recent lbprefs files here.
With one Screenshot of the filenames, showing which directory the .lbprefs file is in and with one lbprefs file I assume I can see where something might be going wrong.
Happy to help if I can.
