Lightburn Crash Log
hallo, ich bekomme immer eine Fehlermeldung und lightburn stürzt ab.
hier ist der Crash Log
Crash Log Stack Trace for LightBurn v1.4.03:
QAction::setEnabled
CameraControlWidget::ReleaseCamera
CameraControlWidget::~CameraControlWidget
CameraControlWidget::`vector deleting destructor’
QObjectPrivate::deleteChildren
QWidget::~QWidget
<couldn’t map PC to fn name>
is_exception_typeof
_C_specific_handler
is_exception_typeof
_CxxFrameHandler3
_GSHandlerCheck_EH
_chkstk
RtlUnwindEx
_C_specific_handler
_chkstk
Undo Stack:
Change cut settings
Set cut output flag
Set cut output flag
Set cut output flag
Set cut hide flag
Set cut passes
Change cut priority
Delete shapes
Set cut hide flag
Set cut frame flag
Set cut frame flag
Set cut hide flag
Set cut hide flag
Set cut frame flag
Set cut frame flag
Clear selection
Move selection
Duplicate selection
Move selection
Duplicate selection
Select object
Move selection
Duplicate selection
Move selection
Select object
Duplicate selection
Move selection
Move selection
Duplicate selection
Move selection
Rotate Selection
Move selection
Duplicate selection
Move selection
Duplicate selection
Move selection
Duplicate selection
Move selection
Move selection
Duplicate selection
Move selection
Duplicate selection
Move selection
Duplicate selection
Move selection
Duplicate selection
Move selection
Select object
Clear selection
Move selection
Move selection
Select objects
Clear selection
Select objects
Clear selection
Rasterförmiges Array erstellen
Select new cut index
Select object
Delete selection
Select objects
Move selection
Select object
Clear selection
Set cut hide flag
Set cut output flag
Move selection
Select object
Set cut hide flag
Set cut hide flag
Set cut frame flag
Set cut frame flag
Set cut hide flag
Set cut hide flag
Set cut output flag
Set cut hide flag
Set cut output flag
Set cut hide flag
Set cut output flag
Set cut hide flag
Set cut output flag
Set cut output flag
Set cut hide flag
Set cut hide flag
Set cut output flag
Move selection
Move selection
Select objects
Clear selection
Move selection
Select objects
Clear selection
Scale Selection
Scale Selection
Scale Selection
Select object
Clear selection
Move selection
Select objects
Clear selection
Scale Selection
Scale Selection
Select object
Clear selection
Move selection
Select objects
Clear selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Select object
Clear selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Select object
Clear selection
Move selection
Select objects
Move selection
Select object
Clear selection
Select objects
Clear selection
Move selection
Select objects
Set cut frame flag
Set cut output flag
Set cut hide flag
Set cut hide flag
Set cut output flag
Set cut output flag
Set cut hide flag
Set cut hide flag
Set cut output flag
Set cut hide flag
Set cut output flag
Set cut output flag
Set cut hide flag
Set cut hide flag
Set cut output flag
Select objects
Move selection
Select object
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Create Rect
Clear selection
Move selection
Select objects
Move selection
Select objects
Move selection
Select objects
Clear selection
Move selection
Move selection
Move selection
Move selection
Move selection
Select objects
Move selection
Move selection
Move selection
Select objects
Clear selection
Move selection
Move selection
Move selection
Move selection
Select objects
Clear selection
Select objects
Clear selection
Move selection
Select objects
Clear selection
Radius corner
Remove Radiused Corner
Radius corner
Radius corner
Radius corner
Radius corner
Radius corner
Radius corner
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Scale Selection
Create Rect
Clear selection
Select object
Clear selection
Select object
Select object
Delete selection
Select object
Move selection
Move selection
Duplicate selection
Select object
Delete selection
Move selection
Move selection
Move selection
Move selection
Duplicate selection
Select object
Clear selection
Edit Vertices
Edit Vertices
Edit Vertices
Edit Vertices
Edit Vertices
Edit Vertices
Edit Vertices
Edit Vertices
Select object
Edit Vertices
Edit Vertices
Select object
Edit Vertices
Edit Vertices
Edit Vertices
Break Shape
Edit Vertices
Edit Vertices
Edit Vertices
Break path
Select object
Edit Vertices
Edit Vertices
Edit Vertices
Delete Vertex
Edit Line
Edit Vertices
Edit Vertices
Edit Vertices
Edit Vertices
Break path
Select object
Redo Stack:
Support Data:
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
