Thank you for reporting this issue. This should not be happening in any version of LightBurn. What version of LightBurn and OS are you running? Do you get a crash report? If so, please send it to us via email to developer at lightburnsoftware dot com and we will investigate.
As a side, the Trial version is the full version, just time limited.
How do I generate a crash report?
Kudos to you guys! It is a wonderful piece of software, And it is also nice to see how fast the response is for a bug
When this happens, are you getting any error message displayed? Any more information than “boom”? You also have not told us the version of LightBurn nor the OS you are using.
Edited: Just tested your steps without issue. No boom. (Mac DSP ver 9.02; OS X - 10.13.6 - 17G6030)
If you’re using the 64 bit windows or MacOS versions you should get a call stack or crash report. You can send these to developer at LightBurnSoftware dot com along with whatever you remember about how it happened. If it was a specific font, for example, that would help,
I can duplicate this behavior on the latest beta on Linux 64-bit. Create text, select all text, and try to change font. Lightburn crashes and closes immediately. Doesn’t seem to matter which font
Ahhh… I’ll have to go dig through my emails then. I think this is an issue with Ubuntu itself, or an interaction with the Qt framework, based on when I tracked this before. 18.04 doesn’t have the issue.
I am having the same issue on my 7w tech laser on a Shapeoko3. When I attempted to edit text, this is the msg I received.
Qtextoptions:tigger shape rebuild
Qtext option::qt_metacall(151)
Qmeta object::activate
Qwidget::event
Qapplication private::notify_helper
Qapplication:notify
Qcore application::notify internal 2
Qwidget:: set focus widget
Qwidget::set focus
Qapplication private::give focus according to focus policy
Qapplication:: notify
Additionally, when I check the machine setting tab it says connection to controller failed. My Lightburn version is 9.02.
Thanks
Mike Runyan
I run windows 10 and it happened on one of the fonts I downloaded(pieces of eight) and new times roman that came with the LightBurn program. When the msg appeared my project continued until I clicked ok. Then it closed the program.
Can you send me the link to where you downloaded that font? I’ll see if I can reproduce the issue. There’s a good chance this has already been fixed, but I’d like to be sure.
