Does anybody else have this issue with LightBurn? When previewing the file or trying to start it on the laser, LightBurn crashes at 57%. I changed the DPI much lower to see if that is the issue, but I run the DPI on other files and they run fine. I searched online and this does not seem to be an issue. Running 1.7 on Windows 11. I watch the memory when this happens and it only uses maybe 5% of my memory. Thanks for any help!
Any luck with this? im facing the same issue
Hi Will
Could you send this LBRN file to support@lightburnsoftware.com please
Would be very helpful to try to replicate the issue.
Got mine working! Check Dpi or adjust image in the setting to a lower dpi, i had mine on over 1000 and now lowered to about 340. It seems the higher the dpi the slower it takes to create each image slice and at a point it seems to bonk out. Does this have to do with ram or CPU?
Can you attach (or email) the file you’re working with? I’ve run the numbers and the settings you’re using shouldn’t be using enough RAM to cause it to crash.
I have a new image resampling engine in the works that is much more accurate and uses less intermediate memory, which should help.
