Hello everyone… I have one question about dimension change… If i download some format to cut it on laser i cannot change dimension size in lightburn… like on picture original dimension is blue line… I want to make it bigger like show on red line… if i choose picture it choose me all cut line… i cannot choose only part where i want to change dimension… Because if download vector use 3mm wood and i want to use 4mm it cannot fit… How can i change that?
You won’t be able to use the Slot Resizer if the shapes are broken into segments.
To use Slot Resizer you can delete the red rectangle and select only the blue shape. However, that may not work best in this case, if you only want the slot resized in one direction- the area where the red shape is overlapping the blue.
If that’s the case, keep the red rectangle and use Boolean Subtract to remove its overlapping area from the blue shape.
If you’re still having trouble after trying that, please share your project here so we can take a closer look.
