First of all, LightBurn is fantastic. Together with the controller upgrade, it makes my K40 a real workhorse.
I installed LightBurn on my Mac and it works fine out of the box. But because it’s the laptop I use for my work, I’m not that keen on always taking it to the lab where I have my K40. So I invested in a second hand Lenovo X250 on which I installed ElementaryOS.
Now, the problem is that LightBurn can’t find the controller (LO-E5) on the X250. However, I see the device is present using ‘lsusb’. It advertises itself with ‘NXP’.
The ‘lsusb’ command lists the following information:
1fc9:0085 NXP Semiconductors
When I look that id up on www.linux-usb.org/usb.ids, I find the NXP section (1fc9), but 0085 is not listed as a device.
Is there something else I need to do / configure / install?
It’s likely a permissions issue or something needs to be updated in the udev rules. I’m not really familiar with Elementary OS - in theory it should work as it’s Ubuntu based but, for the record, we test on Ubuntu and Fedora and anything else may have issues. There’s just too many variables.
One thing I’d try first is to run as root. Assuming you installed with the .run file download, please run this: sudo ${HOME}/.local/share/LightBurn/LightBurn
You will have to setup your device profile again unfortunately as they are per user.
If that still doesn’t work, can you please provide the output of the following commands:
uname -a
#connect your controller and then immediately run
dmesg | tail -n=100
Also, trying to connect to the device after having run lightburn from the console (using ${HOME}/.local/share/LightBurn/LightBurn) may provide debug information that will help.
Note that ttyUSB is likely wrong as I don’t know what the device name in your case is… plug in your controller and then immediately run dmesg and check that log. Should have a device name in there. Then sub that in for ttyUSB
Hopefully that should be the only thing you’ll need to change.
You may need to reboot to have this take effect but you can also try running: udevadm control --reload-rules
