Lightburn doesn't seem compatible with my Jinsoku LC-1620, X and Y co-ordinates are different (seem to be reversed)
As mentioned , Lightburn is showing standard X and Y axis configuration. My Jinsoku is showing it as Y and X axis . Also the 0,0 point is showing on the left side of my machine. Does niot make sense and can’t find any documentation to suggest a fix. Thx for any help.
What OS including version & Lightburn version are you using?
You may have the setup of your device reversed.
try setting your laser start point diagonally opposite to your current setting.
most Diode Lasers has the starting point on the left side front.
