LightBurn Gcode errors
Each time I attempt to burn an arc or circle, the laser starts briefly and then stops and gives a 20 gcode message. This is on a SculpFun S9 Laser
Make sure your laser is set to the correct device type. Follow these steps to check:
-Click “Devices” in the ‘Laser’ window
-Double click your laser in the list
-Change the selected to ‘GRBL’, if it is not already
-click next until you’re done
If that doesn’t help, please save and send us the GCode from a test project, so we can take a closer look. File > Save GCode > upload it here (you’ll need to change the extension to ‘.txt’)
Additionally, make sure that you did’t turn on “gcode clustering” in device settings.
