Due to significant EMC interference that I am unable to eliminate (caused by numerous inverters and converters in a relatively small area), I kindly request the implementation of WebSockets or another mechanism that would allow connecting grblHAL to the software via Ethernet.
Despite using shielded cables (Siemens) and ensuring proper grounding of the installation and the machines’ metal parts (eliminating ground loops, etc.), USB connectivity does not allow for stable operation.
Especially since other controllers can be connected to LightBurn via Ethernet.
You don’t mention the hardware you use, so It’s more difficult to make sensible suggestions.
If I configure mine for grbl, it asks the connection method, USB or Ethernet. You have to give it an IP address during configuration, but the configuration seems to already exist.
I don’t run grbl and I don’t know what kind of hardware you’re using…
I have a Teensy 4.1 and 15 years of networking experience; I am confident I understand how IP addressing works.
Ethernet is much more resistant to interference and offers much more stable transmission.
We’d know you had this experience by? Sometimes we are lucky enough to get someone to plug the Ethernet cable in correctly…
I’m less worried about your experience than what hardware is there and wired up. I don’t see a Ethernet on any of the Tiny 1.4 machines I looked at on the Internet.
So I’m more confused on what you’re doing and how you’re thinking…
I’m not spending a bunch of time to help you fix your own problems. A yes I have Ethernet connection or no I don’t would be simple. I’m not reading a manual to see what you have.
Look, man, if my first post asks for support for Ethernet communication—whether it’s WebSockets, Telnet, or whatever else grblHAL supports on my controller—then the answer should directly address that question. You should be posting links or images showing the controller board where it’s obvious that it has an Ethernet PHY and the connectors needed to access it.
Your problem is that you just rack up post counts with content that achieves nothing but a mess. I have a serious request: please do not reply to my future posts.
I know Dr. Jack (@jkwilborn) sometimes has an abrupt bedside manner, but he has valid questions and statements. I have been following this Thread and I too wonder why you need WebSockets to make yours work. You should be able to plug in the I.P. information and it communicate.
I pulled this from another Forum posting:
Falcon Design Space uses WebSockets to remotely control the laser. LightBurn does not use WebSockets (yet).
The protocol would be complicated to implement because every manufacturer uses different “handlers”
There a lot of CO2 lasers using Ethernet for communication, without WebSockets, but I found no reference where that was the only option for any machine. If you prefer to only do it “your way”, I expect Jack is not the only one that will quit responding. If Lightburn does not support WebSockets, and that is all you think will solve your problem, then there is no correct solution for you. I was a Windows Application developer and Web Administrator in a past life, but I think I should not Reply to your future posts either.
And I think you owe Jack an apology. He is a volunteer just trying to help.
You should be able to connect using Ethernet or WiFi with grblHAL if your controller supports it.
When configuring the network options in grblHAL (in the webbuilder) after choosing your ethernet module or WiFi make sure you also check the ‘Telnet server’ option:
You will then need to connect to your controller by USB, and configure the network settings, for mine I enabled ‘Sta’ mode, and entered my network SSID and password, and rebooted it.
In LightBurn set up a new GRBL device, enter your IP address:
in my first post was “I kindly request the implementation of WebSockets or another mechanism that would allow connecting grblHAL”
“or another mechanism”
I apologize, but in my first message, I clearly stated that it could be a different mechanism—and I also mentioned Telnet in the messages that followed.
I never stated anywhere that a WebSocket was a necessary requirement.
No real apology ever starts with the “but” disqualifier. A better start would have been, “I did not expect such a reaction to my posting, but…”
No matter, it is @jkwilborn that has the experience with Ethernet and lasers. Telling him to “read manual” was insulting to all of us.
These Forum threads and posting often go “off topic”, but that is the beauty of them. Ideas are shared freely, but sometimes they are a little out of the light beam. But this is not a bad thing. You never know what little tidbit of information will be useful to someone else. If the subject matter strays too far, the moderators will handle it.
There is one common thread through all these postings, and that is that we want everyone to have functional machines, including yours. Then they can share their discoveries and projects (good or bad) with the rest of us. That is how we all grow.
Now the question is, “Did the information @NicholasL provided get you up and running?”
Hello, I didn’t mean to apologize to anyone The question was whether Ethernet communication could be enabled, not whether the controller has Ethernet; likewise, I wasn’t insisting on sockets. Please read carefully. Thank you.
Thank you for the detailed response.
Ethernet communication is working—to the point where position reporting during operation has even started up, something that unfortunately wasn’t possible via USB.
I am no longer experiencing the transmission interruptions that occurred when using USB.
