LightBurn ignores Y settings
Hello,
My program ignores Y position:
I cannot force it to move along y axis both directions using cursors.
It seems that the mashine does some attempt to move but there are only vibrations.
When burning a shape centered in the work area, instead of moving to the center, it does its job using the minimum Ys possible (instead of Y=100to152, it uses Y=0to52).
And it is not the fault of the mashine because in LaserGBRL it works fine.
Regards
In LightBurn, open your project file, the Cuts / Layers window and the Move window.
Then use a screen capture tool to capture the screen:
and upload or drag & drop that captured screen into a file here.
A clean digital image is much easier to read than a cel phone picture. It communicates more fully.
