I have been having troubles with this puter, and lo and behold today LB has disappeared from this laptop. Well off of the desktop anyway. It’s probably a simple fix but being computer illiterate, plus the age thing, I am asking for help in getting it back on desktop. Thanks to all.
Did you accidentally delete the LightBurn shortcut on your desktop or unpin it from the task bar?
If you go to the start menu and type LightBurn, does the option to launch the program appear?
You can always download and reinstall the version you were using previously. If it wasn’t the latest version 2.1.04, you can find all versions by clicking on Past Releases:
Well Jess, I did not do anything like that intentionally. But must have. I was able to some how find it and use it and it is now on my task bar. But not my desktop yet. Thanks.
You can hold the CTRL key and drag a copy back to your desktop. Easy fix.
Unable to download. I’m told that disc is full. ???
So if my disc is full would it atomically delete something.?
I was able to use LB a hour ago even though there was no app on desktop.
Grrrrrrrr…
Which “disk”? The PC or the laser?
Not that I ever heard of.
A full disk can keep you from running or installing something. In Explorer, clcck on the C:\ , then right-click and select Properties. That will tell you if it is the PC.
Edit: Click on the Recycle Bin. It may have years of deleted files.
PC disc.PC disc. So I am trying to delete stuff now. This is where things really go bad, ![]()
CCleaner ( free Download CCleaner | Clean, optimize & tune up your PC, free! ) is pretty good for cleanups. Just be careful with deleting cookies..
