Lately I have been experiencing this issue with LB not accepting keyboard inputs anymore and I have to close it and reopen for it starts working again, but only for a few minutes before the issue starts again. It is a frustrating cycle.
I often keep transferring shapes from Illustrator to LB via cut & copy to speed up my workflow instead of importing the files from Illustrator.
The issue with LB starts when trying to resize a shape in the options panel and not accepting my keyboard’s numeric pad, but it would accept the keys on top of my keyboard instead, but now it ignores any of keyboard’s keys completely. However, if I use the font tool, I can use my keyboard normally, but when trying to resize a shape or save it to my Art Library, it will not work at all.
I am using a regular keyboard and I have the latest LB version (2.2.00). I am not sure if this version is the culprit of my issues or if I can return to the previous version.
Also, I known my keyboard is not the issue because it works perfectly with my other applications
Are you sure the keyboard only doesn’t work in the Lightburn software? Have you tried it in other software like Word or Excel, for example?
This problem sounds like Num Lock is disabled to me. Check if there’s a key on the top right of your keyboard that says “Num Lock”. Press that key when you check the problem to see if it solves it.
As I mentioned before my keyboard works fine on any other application, such as Word, Adobe applications, all Windows applications, etc.. The Num Key is not disabled as I use it everywhere. I tried disable it and enable it again, but as I mentioned before, the whole keyboard keys, except for the arrows, stop working. Everything starts working again after I restart LB, but only for few minutes before the issue start again
