Lightburn (lastest release) omni one uv
Many of us come here with problems and I am not different.
I have an Omni One UV 5 watt. I have done exhaustive checks and troubleshooting.
my laser is communicating with the computer, however the framing function is not working and when the laser is tasked with a job, the result is a power out (no matter what setting is used) to light even to mark paper.
power supply is good.
so I have to ask can anyone work with me to track down if there is a software error? A setting I have wrong. please PM me or use [redacted - do not post your public email on the forum] I really need help. And this laser have functioned well for over a year, till now …hardware or software I need help
Bob
What changed? You can roll back to a previous version if necessary. If it is a version update, did you try loading an older .lbprefs into the new version?
Are you using the fluorescent paddle to view the framing output?
Is the lens cover removed (we do see this on occasion, I have to ask)
Have you confirmed focus is correct? Try putting a piece of scrap material (cardstock works well) at an angle under the beam and etch a large square. areas that are in focus properly will mark.
MIKEY, I lost function on the framing and the flourescent paddle does not help.
Loaded the. lbrefs the new version of lightburn works well, the lens cap is OFF, lens is clean
I believe I have located the problem, and error in the PVM unit. Communications with machine are good, the mirrors are clean and fully functional.
Bob
I’m not sure what a PVM unit is - can you explain?
I’m also curious what a PVM unit is :slight_smile:
Did you verify that the hardware works when using ComMarker Studio?
This was recorded as the PVM module or unit I am currently awaiting response from Commarker for pricing a new board.
any further suggestions or troubleshooting advice is STILL apriciated maybe I am wrong but I have a red LED and I did not have one before,
Bob
Hello my is there another name for this module my computer seems to be communicating with the laser just VERY LOW POWER AND STILL NO FRAMING EMISSIONS THIS IS WITH THE PADDLE CAN ANY ONE HELP ME TRACK THIS PROBLEM< THE LASER CONTROL MODULE OR (PVM) SEEMS TO BE FUNCTIONING NORMALLY TRY AS I MIGHT I HAVE VERY LOW POWER FROM THE LASER. MIRRORS ARE WORKING
BOB
i AM STILL HERE STILL TROUBLE SHOOTING
The Image shows the “Controller Board” of the laser. That’s the interface card that connects to LightBurn via USB, and controls the laser source, galvo head, and motors of your machine.
I can’t directly comment on the red LED, but there’s a green LED right next to it. Red usually means: bad.
For further troubleshooting:
