Hello, forum friends.
I started having issues with LightBurn related to G-code generation. For example, I tried cutting a 51x51mm piece, but it comes out as 51x59mm. The distortion only happens on the Y-axis.
This problem occurs only in the G-code because if I command the machine to move 50mm on the Y-axis, it moves correctly. If I run the frame function, it also stretches the piece only on the Y-axis.
frame example:
G00 G17 G40 G21 G54
G91
M3
G1 X51.302Y0S5F6000
G1 Y58.642
G1 X-51.302
G1 Y-58.642
M5
G0
G90
Notice that the measurement on the Y-axis is completely wrong.
