LightBurn Mintion Lasercam2 via Splitcam/WiFi
Hello,
I have purchased a Mintion Lasercam2 for my Algolaser DIY 5W.
I would now like to integrate the camera into Lightburn via Splitcam using WiFi.
The image is displayed correctly in the camera’s web interface.
The same in Splitcam.
I calibrated the camera using the dot map.
When updating the overlay, the image is unfortunately also strangely cropped.
What have i done wrong?
Just tried the software from https://ip-webcam.appspot.com/ and calibrated again.
Preview seems much better but the overlay is still strange.
Greetings
Fenris
LightBurn does lens distortion and perspective correction to the overlay. The “blank” portions of the overlay represent areas of the image that were cropped or unavailable as part of that process.
Your camera is likely mounted too closely to the laser and looks slightly askew. If you want the overlay to go edge-to-edge then I’d suggest trying to straighten the camera as much as possible and raise it slightly. Note that the laser overlay should function even with the cropped areas.
Thank you, i have repositioned the camera and completely restarted the calibration process.
Now everything fits as it should!
