If I set the feed rate in settings to be 25.4 mm/sec, there is a comment in the gcode that reflects the setting. However, the F command in the gcode shows F1524 which is 60 times what I entered. So, it seems that LB is translating my mm/sec rate to a mm/min rate. The machine actually moves at the rate that I want, but is this the way LB is supposed to work?
I am attaching a test file to demonstrate what I am talking about.
Thank you.
lb-gs test.txt (280 Bytes)
