Is it possible to activate LightBurn once for all users on a single PC? I am one of a few different users that each need to be able to run our laser cutter. I am able to activate and run LightBurn without issues, but it asks for the activation key when one of the other users logs in to the control PC.
I tried to do this that I found here in the forum:
Windows
1: Update to the latest version of LightBurn and make sure it’s installed and licensed as normal. Close the program or the rest of the process will not work.
2: Open up a command prompt by:
Click Start menu, then type ‘CMD’ and windows will auto-complete,
right-click it, run as Administrator.
3: Type the following into the command prompt:
CD “c:\program files\LightBurn”
4: Next, type the following into the command prompt:
LightBurn -l
Once done, any user who uses that machine will be able to run LB without entering license.
However, I kept getting an error that said: “The syntax of the command is incorrect.” I tried probably 20x and had someone check what I was entering to make sure there were no typos, etc. but still no success.
