Lightburn node editor loses "divide function" since v1.4.00
Hi,
since version 1.4.00 is installed, the node editor doesn’t function properly. In former versions the key to divide nodes was CTRL - B in “node edit mode”, hold B klick node and the line was divided into two.
This doesn’t work any more.
I can’t find how it works now, can anyone help?
Thanks
Joe
You need not hold CTRL or click with your mouse. Hover over the node with the mouse pointer… while hovering push ‘B’ key on your keyboard. That should break the node.
Works ! Thanks a lot
Joe
