I would like to use my Internet while using my laser with Lightburn. I currently connect to my Mira 9 using the wifi option wiht my laser (this means I cannot be on the internet at the same time). I am trying for the 3rd time to get a bridge connected. I have gone through the steps, connected the bridge with my wifi as instructed (it shows as a connected device), but when I go to Lightburn and scan for the device it does not find the device. I am not sure what else to do.
When you set up the device, there is an option for the Lightburn bridge. You have the IP of the bridge to put into Lightburn. Your laser needs to be on the 10.0.3.3 IP, for the bridge to work. I think.
I didn’t think Lightburn actually scanned for the bridge, if I remember correctly, it asks for it’s IP address.
You have to scan for the bridge in Lightburn so you can use your laser. It is not finding my bridge even though it is showing connected in my Wifi list of devices.
I’m running V1.7 When I create a device is asks for the controller type. Then how you’re going to speak to it. If you choose Lightburn Bridge, the next step is the IP of the PI.
Click next takes you to
