I have a Sculpfun S9 running on a Mac mini with Monterrey. It is my first time using a Lightburn and I cant seem to get it to recognize. I downloaded the CH340 driver and still nothing.
What do yall recommend me try?
thank you
thank you
Look in the lower right corner of the window.
Do you see where you chose your connection method (bluetooth or USB)?
Be sure to select USB if you use a USB cable to connect it to a Mac.
Also I had two bad USB cables that would not connect.
Try another USB cable.
I run a Xtool D1 and a AtomStack X7 with my Mac-Mini.
Also have you tried the software that is free with the machine?
Will it connect to your mac using that software?
