MacOS 10.9.5 is the problem. If you can pull that forward to 10.11 it will work. (FYI the current release requires 10.12, but we’re reverting that change for the next release, so it will be back to 10.11 shortly)
The Windows version running in bootcamp should work too. You say “doesn’t work” but you give no indication of why - did it give you any errors?
Thanks for the quick reply.
The error i get in windows is “Can’t find api-ms-win-crt-runtime-l1-1-0.dll”.
I am upgrading the windows on the mac and will upgrade the macOs as well.
Thanks for the help, i will reply if everything is upgraded.
Usually a google search will find these easily. In this case it’s a Microsoft library that is normally present, but not always, so it slipped through. I’ve added it to our next release.
