Lightburn not working with Eleksmaker
Lightburn is not recognizing anything from the eleksmaker.
The 200 by 300 that shows in lightburn does not corespond to what the laser thinks its limits are.
The speed stays the same no matter what the settings.
and when you select fill it decides for itself if to fill or to line.
What can I do?
Start here: https://wiki.eleksmaker.com/doku.php?id=elekslaser_a3_pro
This is worth reading to ensure you tell LightBurn exactly what you have: https://lightburnsoftware.github.io/NewDocs/AddingYourLaser.html
This section for details on grbl setups: https://lightburnsoftware.github.io/NewDocs/CommonGrblSetups.html
Thanks for the links.
Unfortunately that didn’t help.
Lightburn recognizes that I have a laser, but…
Speed stays the same no matter what settings I put in.
When i tested with 2 circles on 2 different layers, both with fill, the laser filled one and outlined the other.
The laser doesn’t recognize the 200 by 300 that I set up and keeps trying to go out of bounds.
