Are you saying it moved both? If so, can you describe how and where you connected the rotary?
With Y-Axis enabled, the Laser head moves along Y-Axis, no rotary movement.
With A-Axis enabled, the rotary turns, Laser head does not.
On the Wecreat Vision Pro 45W, there is only one port to plug in the rotary.
Not move at all or just not move in the Yaxis?
Sorry for all the questions, but I cannot see what you do, so you have to be my eyes. Detailed descriptions help.
With the A-Axis enabled, the rotary works correctly. Laser moves along the X-Axis and rotary rotates.
Only issue, its locked at 360 degrees per rotation, but actually turns about 580-600 degrees.
Not sure what you mean by “locked”. Can you set the steps per millimeter in the Rotary Settings window to about half? That is what yuo adjust to get exactly one rotation of the chuck with the Test button.
Unfortunately, when the A-Axis is selected, you cannot adjust the degrees per rotation.
When you load the Wecreat configuration file into Lightburn, it provides some Macros. In order to get the rotary to work using the “Test” button, you must first engage the rotary by clicking the macro. After that, it will only work with the A-Axis selected. I renamed my macros but below is a picture. The preconfigured name is “Enable Umode”.
After running some test (more will be needed), I have figured out that you need to set the diameter of your object differently. Based on my findings, the 80mm diameter tumbler I was testing, I must set the diameter in Lightburn to 134.55mm (Actual Object Diameter (mm) x 1.682). Testing was run by using a 1x1 inch square.
More to come…
Thanks for the details. I am sure this will be a big help to others with the same machine.
Issues regarding speed differences. Both projects were running at 350 mm/s and there is a significant difference between the two software’s. I actually used the same file for both for the test. I was going to post a clip of each running, but you are unable to attached videos. Is there a way to get Lightburn to run at the same speed as Wecreat’s MakeIt Software?
You tell Lightburn the Units and how much, like 2500 mm/m. I presume you do the same in MakeIt. Lightburn has the option to run at fixed speed or slow down for the corners.
In Lightburn, I have the speed set at 350 mm/s, same as MakeIt. The laser in Lightburn doesn’t move at the same acceleration as it does in MakeIt.
350 mm/s in MakeIt (Normal)
350 mm/s in Lightburn, seems the setting is actually running at 200 mm/s.
There are other things in play here, so this might not be a 1:1 comparison. For example, do you have Constant Power Mode turned on in Lightburn?
There are two variables that control speed in the controller, MAX Speed and MAX Acceleration. Neither MakeIt nor Lightburn modify these when running a program. If the project settings in MakeIt and Lightburn match 1 for 1, then the performance should appear the same.
Can you save a GCode file with MakeIt?
Constant Power mode is turned off in Lightburn.
The MakeIt software does not expose the G-Code nor allow it to be saved or exported.
I currently have 2 lasers running off Lightburn (Wecreat Vision Pro 45W and TwoTrees 22W). Neither have communication with the controller. I know the TwoTrees has in the past but at this moment it doesnt.
Have you viewed the Console window for any possible text?
Ill look for this next time I am running the laser.
Attached are screenshots of the configuration file for the laser.
I see it says “ComPort”: “COM5” but Windows assigns the COM port as it sees fit. Windows’ Device Manager will show what COM port to use in Lightburn when you connect the laser USB cable.
Also, you cannot have MakIt loaded with Lightburn. They will both be fighting for the COM connection.
I have the WeCreat laser set on COM5 and my other laser set on COM4. This way I am able to run both softwares simultaneously.
That’s expected. The WeCreat doesn’t work like standard GRBL firmware where you could change the $$ values.
Perhaps the Y-axis needs to be suspended separately when the rotary is connected?
Their Macro “Enable Umode” contains M16. We don’t know what this does to the device.
It’s essential to power cycle the Vision when switching between applications!
The controller has multiple MCUs that need to be restarted in different modes.
The “Enable Umode” locks the rotary in place so you cannot turn or adjust it.
If you need to adjust your object, clicking “Disable Umode” will unlock the rotary so you can turn by hand to the desired position.
I am mainly using Lightburn for both lasers now. I have both setup using USB cables to specific ports.
