Lightburn on an Epilog Laser
I was looking at an Epilog CO2 laser. I asked the company if their machines worked with lightburn. They weren’t sure as they support Corel draw. The said all files are sent to an Epilog print driver for processing. So my question will Lightburn work?
Welcome! We are making progress as you can see from the post below:
When you are setting up lightburn it looks for the laser. Since the file is output to a print driver I asume the “setting up the laser” like i did for the Ortur is not required
LightBurn needs at least one Device Profile defined to work properly. I would suggest you create a profile that matches the size of your laser bed, so the design work matches that of the physical system.
