Lightburn origin not transferred to OF Elite
Hi Forum,
If I import an NC file from lightburn into my 1F Foreman, I notice that it doesn’t start from the origin of the machine. In my file I use workpiece origin. But as the picture shows it starts completely in a different direction.
This my order of working:
Start the 1F
Home the machine
Load file
set 0 manually on the workpiece (position laser and when done tab XYZ as 0)
I wonder, if I home the machine, should XY be on 0
If that’s how you want it to work then try setting the Start From field in Laser window to “Current Position” prior to generating the gcode. Make sure you change the relative 9-dot Job Origin to the relative starting position that you expect. Based on your workflow it sounds like you expect this to be the center position but can’t tell.
Please report back your findings.
