Good morning, I had a problem with Lightburn after the 21.04 update:
all movement if you sleep invert the sense of movement up-down right-left
Starting the machine, the machine makes 2-3 movements with the laser off and then it stops.
I pay for the Lightburn program annually and punctually.
I uninstalled the program and then installed it again but the problem continues, I was installing 21.04 and I was installing previously with 21.00.
The return doesn’t activate the connection, if it moves the other way, it doesn’t proceed with the work… it’s complicated even if I make mistakes and make it come back to one another and appear to be new. Practically Lightburn doesn’t work.
Which one could I use?
thank you
about every 20 runs my “Ruida” will stop part way or rerun the previous job. frustrating. I usually restart the machine and then toggle the LB device selector to another laser then back to the ruida. is the problem in the laser memory or the computer memory or in LB??? I know just enough to be dangerous.
I resolved It with IA: $32=1 and $22=1 on Console now it’s ok. Thanks
Hi @LeoCasa
Glad you have it working.
Just to clarify for anyone finding this later: $32=1 enables GRBL Laser Mode, and $22=1 enables homing. Neither setting reverses the direction of the X/Y axes, and these settings are stored in the controller rather than in LightBurn.
If the problem returns, please don’t change additional $ settings yet — post the machine make/model and the output from $$ in the Console and we can see what is actually configured.
@Rick292 — your Ruida issue sounds unrelated to this one. Please start a separate topic for that so we can troubleshoot it independently.
