Lightburn program running in windows mode floats behind my dock
What’s the resolution of your Mac? LightBurn requires a certain minimum vertical resolution which may be why it’s being drawn beneath the dock.
MacBook Air 2015 (1440 by 900 (native)). , 1280 by 800, 1152 by 720, and 1024 by 640 pixels at 16:10 aspect ratio; 1024 by 768 and 800 by 600 pixels at 4:3 aspect ratio
Yes I can do that I also. can run it full screen mode
No just in windowed mode , others work f8ne
LightBurn itself will take around 800 pixels vertically. If you add roughly 50 pixels for Mac title bar and window decoration you’re already getting close to 850 pixels. So whatever height the dock is over the last 50 pixels will be obscured.
You might be able to recover a tiny bit more space if you go with a single pane on the right instead of the 2 stacked panes.
