Lightburn Rotary tool not functioning properly?
I seem to be having an issue with my rotary tool that I have, I am setting up the rotary tool and for some places the tool works just fine and as it should. There are other places such as the right side of the object where when I frame the sketch (on the right side), it appears in the correct spot and then when I hit start the object rotates and then the laser engraves the part on the left side. I have my rotary tool on the left side of my table and it is set up to be rotating along the y axis. is there a way to fix this?
Does the image come out mirrored?
I don’t have a fiber, but I assume there is a ‘start from’ and a ‘job origin’ that is user set…
Ensure they are set properly.
