Lightburn screen and Preview screen
OK a bit frustrated. Yesterday I ran my project just fine. But today, Lightburn screen and Preview screen not same but end results match the preview screen???
VS.
Left side bottom, right side 1, 2 & 3?
send the lbrn2 file, otherwise we’ll just guess
File in question:
Tray1.lbrn2 (75.0 KB)
You have a 1.6mm kerf offset. That is why the tabs are squashed so much.
OK, this being the case, tell me why this changed from one day to the next.
I have noticed this happening in the past how settings change. It seems one has to go through the settings prior to running each job. I do not remember having to do this with previous versions.
Is this a BUG? :beetle:
I don’t think so, then there will be more people reporting it.
I am continually impressed by my ability to mistakenly click that instead of this, resulting in a setting change making absolutely no sense a few days later.
To counter that, I have an extensive Material Library with the layers in each job linked to entries with useful names. Any change to the job settings starts with an update to the library entry, so all subsequent jobs referring to that entry use the new values.
As a quick check with expensive materials, I verify:
  • Layout targets match material targets → good positioning
  • All layers refer to named library entries → (probably) good settings
  • The Preview looks sensible → good object selection
That doesn’t eliminate all my screwups, but it’s depressing how many it catches. :man_shrugging:
:upside_down_face: :face_savoring_food: :zany_face: :zany_face: :squinting_face_with_tongue:
The more I feel I’m getting the hang of this, the more I find I don’t know :poop: .
I am thankful to have this forum to help me unclog my brain. :plunger:
BTW, when I opened my file this morning and looked at the Kerf Offset for this file, it shows 0.063 as it should be?
I’m beginning to think I have GREMLINS. :alien_monster:
It shows 0.063 inch, which is exactly equal to 1.6 mm.
If you have the Link Design and Control Units switch On, then changing the Design Units in the LightBurn workspace with the Numeric Edits toggle will also change the control units for the machine.
If that comes as a surprise, as it does to most folks, and you really like inches, then:
DUH!!!
OK, the light just went on!
I am continually switching from mm to in While building. I did leave it set to inches when running the last attempt. This is the cause of the issue all along.
I am feeling “stupidly enlightened”. :smiling_face:
**ednisley**Leader is a Genius!
Thanks!
You should see my BTDT t-shirt collection … :grin:
Hey! When you got it flaunt it, right?
Sometimes: “When you can’t fix it, feature it.”
Got the first file to run, finally.
Second file set as 200 speed and 90 pwr. It runs like at 1000 speed. Set for mm.
I’ll upload the file tomorrow.
It’s not that I’m not going to believe you, but a screenshot showing the units will go a long way toward convincing me we’re over the exquisite little inconvenience of wrong units. OK?
Start by always including the units, because “200 speed” doesn’t tell us anything.
If the first file has many small vectors and the second file has many long vectors, then the first file is running much slower than you think and the second file is about right.
FWIW, measure the actual speed with a video camera set to a known frame rate. A cellphone camera taking 1/8 slow-motion video (240 fps?) will suffice if you have known-length vectors letting the laser head apperar in at least two frames. Verify the frame rate with engraving runs at various speeds.
I think sometimes loading an in-between file changes some settings. I have adopted a habit of checking everything in the Cuts Editor window just to make sure.
Tray1b.lbrn2 (62.4 KB)
Here is the file I was referencing earlier.
File runs way faster than set in the CUT file, which is Speed 105 and Power at 90. Settings are enough to cut through 3mm ply but runs so fast it only leaves a thin engraving outline of the cut.
Note to Moderator: should you deem needed feel free to move to a new topic.
There we go with no units again.
Speed 105 is mm/s, which is 6350mm/m and 90% power on a 5w diode. This is waaayyyy too fast to cut 3mm in a single pass. My 10w runs 800mm/m at 90%, 6 passes to cut 3mm Baltic ply. You will need more passes or less speed to to the same cutting.
As loaded here:
You are thinking in either mm/min or inch/min, with LightBurn set to mm/s.
You can change either your thinking or LightBurn’s settings, but until you do, this nonsense will continue.
To repeat: Always include the units, because “200 speed” doesn’t tell us anything.
