LightBurn Seems to fall Asleep
Using Windows 11
Aufero Laser 1 LightBurn Ver 1.0.06 -
Problem - At times seems when software is on idle not being used the software will do this. Wont connect to laser just can’t find it. I go to save my project and it says it saved but never writes the file. IIt also wont load any files or images.This only happens when it won’t connect. I re-start LightBurn and it still wont connect, I reset my computer works fine. I cant figure this out. Besides this issue love the software
Look for a file called “LBFileDialog.exe” in the LightBurn installation directory (usually C:\Program Files\LightBurn).
Make sure LightBurn is closed, rename that file to “LBFileDialog.exe.bak”. Restart the application and see if that changes any of the behavior.
Ok did the above and I will let you know.
Thanks
