Lightburn "SHX-folder"
I got this -german- message when starting LB:
“Das SHX-Schriftverzeichnis ist nicht verfügbar oder nicht vorhanden: F:/Lasercutter/Lightburn”
Found this font-folder nowhere on the PC.
Updating doesn’t solve the problem.
Program runs anyway after clicking - I normally don’t use fonts .
Another PC runs w.o. problems.
Any idea what is the easiest way to solve this problem? (if possible without new installation)?
Maybe create the folder manually copying one font into it or something similar…
Thanks for your advice!
Olaf
SHX fonts refer to fonts that consist of single lines and can/must be installed on the user’s computer individually. In the settings, this font folder must then be referenced.
You can download SHX fonts by searching here in the forum (I don’t have the opportunity right now to refer to it directly) or as you are already on, refer to a dummy.
The font collection is the same, but its location has changed over the years:
ttps://forum.lightburnsoftware.com/t/shx-font-collection-new-home/185935
https://www.burntstuff.com/shop/downloads
Just open the main settings and search for the SHX folder path and delete it. Then LB doesn’t search/check for it.
Found it under “ZIP-Files”, installed it - it works. Thank you.
This works also- LB offers to delete the directory. Doing so the mistake is gone.
But installing it at the path which is shown in the main settings works either.
Thank you very much :slight_smile:
There is an option to ‘Clear the current SHX directory.’
