I have 10.02 lightburn and I send the job to the machine the speed is different
the lightburn software is 15 on the speed and 85 on the power and in the controller is says 381 on the speed and 85 on the power …any help would be great
Well, I’m guessing that your “15” is inches/second and 381 is mm/sec.
381 / 25.4 = 15.
So how do I get them to match up …sorry very new to this
Well, the Ruida contrloller is always going to read in mm/sec. That’s its native units.
Your best bet would be to specify your speeds in Lightburn as mm/sec. Then they match.
If you prefer to work in inches, then in settings you can select “inches / mm/sec”,
which will let you work in inches but specify speed in mm/sec.
Well its works great now and you have been a life safer I was going crazy
Hank thank you …Mark
