I updated this morning to the latest version of lightburn and now I cannot use either laser Machine I own the Ortur LM2 20w nor the YoraHome 6550 3w. The 6550 is running into walls and it does not matter which I use Absolute Coords, User Origin or current position. The frame works perfect but as soon as I go to start it goes all over the place. On the Ortur it just stops and has an error message as soon as I start it. Below are the code
[AUTHOR: RenShen]
[MODEL: Ortur Laser Master 2]
[OLF: 137]
[DATE:01:15:16 - Apr 20 2020]
[VER:1.1f.20170801:]
[OPT:VZD,35,254]
Target buffer size found
ok
Starting stream
Stream completed in 0:00
ok
Starting stream
Stream completed in 0:09
Starting stream
Starting stream
ok
ok
ok
Starting stream
Layer C00
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the âDevicesâ button to reset the connection)
On or near line 4:
Job halted
[MSG:Reset to continue]
Waiting for connectionâŚ
ok
ok
[AUTHOR: RenShen]
[OLF: 137]
[OPT:VZD,35,254]
ok
ok
ok
ok
ok
ok
Starting stream
ok
ok
ok
ok
ok
Starting stream
Starting stream
Layer C00
ALARM:2
On or near line 4:
Job halted
ok
ok
ok
ok
ok
[AUTHOR: RenShen]
[OLF: 137]
[OPT:VZD,35,254]
ok
Starting stream
ok
ok
ok
ok
ok
ok
Starting stream
Grbl 1.1f [â$â for help]
ok
[OPT:V,15,128]
ok
ok
ok
ok
ok
ok
Starting stream
Stream completed in 0:10
ok
ok
ok
ok
ok
Starting stream
Starting stream
Starting stream
Starting stream
Starting stream
<Idle|MPos:76.963,26.950,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Layer C00
Job halted
Stream completed in 0:03
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
[MSG:â$Hâ|â$Xâ to unlock]
[MSG:Caution: Unlocked]
ok
ok
ok
ok
ok
ok
<Idle|MPos:254.800,-41.688,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Stream completed in 0:11
ok
ok
Starting stream
Starting stream
ok
ok
ok
ok
ok
ok
ok
ok
Starting stream
<Idle|MPos:254.800,-41.688,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
Layer C00
Job halted
Stream completed in 0:02
ALARM:3
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
Starting stream
ALARM:3
ok
ok
ok
ok
<Idle|MPos:224.263,26.950,0.000|FS:0,5|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Pgm End]
Starting stream
ok
ok
ok
Starting stream
Layer C00
Job halted
Stream completed in 0:01
ALARM:3
ok
ok
ok
ok
ok
ok
ok
<Idle|MPos:373.288,-72.525,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Stream completed in 0:12
