LightBurn vs RDWorks: Plywood Cuts Cleanly in RDWorks but Barely Cuts in LightBurn – Ruida RDC6442S
Hi all,
I’m switching from RDWorks to LightBurn and encountering a strange issue: identical speed, power, and frequency settings produce dramatically different cutting results.
A cut that works perfectly in RDWorks barely cuts through the material when run from LightBurn, even though all the relevant layer settings appear to be identical.
Setup
  • Controller: Ruida RDC6442S, single glass tube on Laser 1
  • LightBurn 2.2.00, device profile “Ruida 644XS”, connected over USB
  • RDWorks V8.01.64
  • Test part: 35×35 mm square with a ~28.6 mm circle inside
Layer settings (identical in both programs)
  • Line / Cut mode, same speed, 1 pass, no Z offset or Z step
  • Min/Max power: identical in both programs
  • PWM frequency: identical in both programs (LightBurn Override PWM Frequency, RDWorks “Laser1 freq”)
  • Air on (manual air, on for both runs)
Already ruled out
  • Units are mm/s, and Min = Max power.
  • Shape Power Scale is 100%.
  • Perforation, dot mode, tabs, ramp, lead-in/out and start/end pause are all off.
  • “Remove overlapping lines” is off. Preview shows a single continuous cut.
  • Controller settings read the same in both programs: Laser 1 min 1% / max 80%, 20 kHz, glass tube, Laser 2 disabled.
  • RDWorks software options: Laser mapping is disabled (1:1), and Small circle speed limit only applies to circles up to 8.1 mm.
The key test
  • RDWorks’ .rd file run from LightBurn using “Run RD file” cuts perfectly.
  • LightBurn’s .rd file run from RDWorks using “UFileOutput” does not cut properly.
This strongly suggests the issue is in the file LightBurn generates, rather than the connection or the machine itself.
What I found when decoding both files via claude
Speed (C9 02 / C9 04), Laser 1 power (C6 01/02 and C6 31/32), frequency (C6 60), and on/off delays all match.
The differences are:
  • CA 03 (laser tube enable): RDWorks sends 0x3D, LightBurn sends 0x01. I patched LightBurn’s file to 0x3D (with a recalculated checksum), but it still produced the same poor cutting result.
  • C9 03 (axis speed): LightBurn sends an additional 15 mm/s command that RDWorks doesn’t.
  • Laser 2 power: RDWorks sends 80%, LightBurn sends 20%. Laser 2 is disabled, though.
  • Path: LightBurn’s file has more segments and a 0.05 mm kerf offset.
  • Header: RDWorks uses E7 32 / E7 3B / E7 0B and CA 10. LightBurn uses F0 / F1 / F2 element blocks.
I’ve attached both .rd files of the exact same test part (RDW3.rd from RDWorks and LB2.rd from LightBurn), along with the LightBurn project.
Has anyone encountered this issue? Is there anything else in LightBurn’s output that could cause such a significant difference in cutting performance despite identical speed, power, and frequency settings?
I’m happy to run additional tests.
Thanks!
LB2.rd (1.3 ק״ב)
RDW3.rd (1.1 ק״ב)
I can’t tell you much about RDworks as I run Linux and it doesn’t run on my machine.
We might have a better chance by posting the .lbrn2 file instead of the rd files.
Period (pwm base frequency) is only used for RF or metal tube sources, not for glass tubes. Although you can change it, once it gets to the lps, it’s turned into an analog dc signal. A period of 50ns (20khz) is the normal setting for dc excited co2 machines.
I loaded the RD file into Lightburn and it seems OK.
Maybe @ednisley can assist us?
:grinning_cat:
.lbrn2 is missing
Thanks for the feedback!
I’m attaching the .lbrn2 project file now.
In the attached project, I’m trying to set the PWM frequency to 10 kHz, because this is the optimal setting I’ve found in RDWorks, where the cutting results are excellent. My goal is to reproduce the same results in LightBurn.
However, I want to clarify that the performance difference is not limited to the 10 kHz setting. Even when using the default 20 kHz frequency in both programs, I still notice a consistent difference.
For example, when cutting 6 mm plywood, I had to reduce the cutting speed by approximately 5 mm/s in LightBurn to achieve the same cutting performance as RDWorks using the original settings.
Both programs are tested on the same machine, controller, and laser tube. The speed and power settings are identical, yet LightBurn consistently seems to produce less cutting power.
I understand that PWM frequency may not have the same effect on glass tube systems, so I’m not assuming this is the cause. I’m mainly trying to understand why identical speed and power settings produce different results.
Could this be related to how LightBurn sends or maps the laser power signal to the Ruida controller? Is there any setting related to laser power scaling, output mapping, or Laser 1 configuration that I should check?
I’d really appreciate any suggestions.
Thanks!
LBRN2.lbrn2 (11.7 ק״ב)
I can’t see anything special in your file that suggests reduced power setting.
If you have an ammeter retrofitted or original in your power supply, you can compare what is sent to your tube.
Tampering with the standard PWM setting of 20kHz can be unhealthy for your tube, especially if you set the frequency up. This function is, as Jack has already written, intended for RF tubes which are differently constructed and also work differently than CO2-glass tubes.
Under “Vendor settings” in LB’s machine settings there is the option to read data from your Ruida, e.g. max power. Could it be that it is set to something other than the original value?
Thanks for the suggestions!
I do have an ammeter installed in the power supply, and I can confirm that the current is identical in both programs when running the same job with identical speed and power settings.
So, in principle, the tube is receiving the same current, but LightBurn still doesn’t cut through the material at the same speed(I know it sound strange) . If I reduce the speed in LightBurn, it eventually cuts through, but the material gets significantly more burned.
Regarding PWM frequency, I’m not increasing it. I’m only lowering it when cutting thicker wood and it help to prevent burning.
As for the Ruida controller settings, the maximum laser power is set to 80%, based on the laser manufacturer’s current limitation. Unsurprisingly, both RDWorks and LightBurn read the same 80% value from the controller.
Could LightBurn behave differently when the controller’s maximum power is set to 80% rather than 100%? For example, could there be an additional power scaling or interpretation of this value in LightBurn that differs from RDWorks?
I’d appreciate your thoughts on whether this is worth investigating.
Thanks!
The number of times we’ve eventually found two identical configurations had different units for speed prompts me to ask: Are you certain LightBurn and RDWorks use the same speed units?
Screenshots of the layer settings for the same design in the two programs would be convincing. :grin:
I don’t see how it could differ.
The laser is running the same current that would indicate it’s same to the tube.
You can check it’s TEM resonance and alignment.
:grinning_cat:
Thank you for this - A few small differences I wanted to run by you from simplest to hardest.
a) Can you run the same test on LightBurn RD file but with kerf offset at 0 and Z disabled?
b) Could we get a visual reference in the same bit of wood, RDWorkds vs LightBurn - at times visual clues are easier to spot.
If the kerf/z test reproduces the different behaviour, could you send us a new batch of RD files
so we can check please?
If all fails, could you downgrade to 2.0.05 and repeat please?
