Hi, I’m new to both Lightburn and to laser burning. I’ve just taken delivery of a Monport 40w CO2 laser engraver/cutter which I bought from Monport U.K. as “Lightburn ready”. I installed the machine in Lightburn as per the Monport instruction manual and have connected to it using my MacBook Pro running Monterey and the supplied USB cable. The problem I have is that Lightburn will not control the Monport, despite the Monport being recognised and installed. As an example, I manually move the laser heads to the centre of the work space and then click “Home” and nothing happens. This is the same if I try to burn something. Any help would be really appreciated! Thanks!
Perhaps previous discussions will be informative:
https://forum.lightburnsoftware.com/search?q=mac%20monterey
You can sort by date and work backwards.
OEM USB cables are typically junk. Buy one with ferrite cores from a known-good source, throw the OEM cable in the trash, and prevent a whole bunch of heartache & confusion.
Thanks for the advice. I’ll do just that!
Thanks everyone, problem solved! I needed to select “cu.usbserial-1410” in the laser control box!
