I have got myself in to a bit of a fix. my Woxcker L2Max was working fine then I noticed that the circles were not right. I recalibrated the machine in Lightburn, using a cut out of 150mm square. The “Y” setting was correct but the “X” setting was only giving me 49mm, so I did the calculations and entered them into the reset axis’s. Now the machine will not do anything. I keep getting error 7/8/9 that all say the machine has not homed properly. If I put the laser head into the middle of the work area and press home it goes one stop then I keep pressing one stop at a time until it is homed. It will also not frame and stops with a jerk after I press frame.
It must be something that I am doing wrong but for the life of me I can’t figure it out.
Sounds like one or more GRBL settings are not correct.
In the Console window, enter $$. Then copy all the lines starting with the $$ and paste it in a Reply. We can then check your GRBL parameters for something that seems out of the typical.
I have tried uninstalling lightburn after deleting the backup files then downloading lightburn again.
This did not work. It is still not Homing and not framing.
I have copied the $$ files. Hope you can spot something that I have done wrong
$0=3
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=500.000
$25=4000.000
$26=255.000
$27=2.000
$30=1000.000
$31=0.000
$32=1
$180=1
$100=5527.571
$101=3398.981
$102=1284.200
$103=100.000
$104=100.000
$105=100.000
$110=7000.000
$111=7000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1800.000
$121=500.000
$122=200.000
$123=200.000
$124=200.000
$125=200.000
$130=300.000
$131=300.000
$132=1000.000
$133=300.000
$134=300.000
$135=300.000
ok
Thanks for the advice. You have 3 outlined 100-101-102 should they all be set to 80 ?
As for the circles not being right which was the reason I did the test in the first place, The circle was being cut as an eclipse and my squares were not square.
As for the circles not being right which was the reason I did the test in the first place, The circle was being cut as an eclipse aI have nd my squares were not square.
I replied to your question about my circle. i have changed $100 ,$101,$102 to .80 The framing now goes to the back frame and hits the stop. The homing still only moves in one stop each time it is selected. I have tried uninstalling Lightburn and downloading it again with the same result. My machine is no longer useful to me. As for sending images I do not know what sort of image you require.
If there’s a decimal point in front of the 80 in the controller, then that will be a problem. The unit is “steps per millimeter” and the value is typically a whole number.
If you set those values to 80 in the controller and just had a typo here, then it’s not a problem; we all do that!
I have no idea what this means. Could you please describe it in more detail?
Any chance you can confirm these values with the manufacturer? They are not anywhere close to what I am accustomed to what I have been seeing. It is possible your machine has non-typical stepper motors.
I have been onthe Woxcker help line but they are not very helpful. I am so frustrated with this machine that I have purchased another one . It is AtomStack A49 Pro V2 . I need to get back to producing items ready for Christmass. Thanks for all your help.
Very understandable. When you get somefree time, revisit this Thread amd we will try to get you a working backup machine. Or maybe even one for parallel processing.
