I went to try and do the white tile method using JTech and LB. when I went to set image burn properties up. I noticed it would not allow me to select anything other than Threshold(grayed out selection). I updated to 9.10 this morning and noticed this. I’ve tried reinstalling both 9.10 and went back to 9.9 with no difference in issue.
You have pass-through mode enabled (the green switch just about the dither sample). That tells LightBurn that you dithered the image outside of LightBurn, and don’t want the image resized, dithered, or otherwise processed in any way.
Thank you I will see if that works!!
Kevin
