LightBurn Work Area is Small laser head goes the opposite direction and everything engraved is reversed
I want to buy this software so bad today but I have a problem with LightBurn’s work area and orientation. I’m using GRBL on a new Wainlux L3 engraver. When engraving the work area is very small and I often get the error “outside of area” . It is probably half the area that I actually have, anyone know how to fix this? Also, if I tell it to print in the lower corner it will actually print in the upper left hand corner. Also, it goes to home position in the upper right corner then immediately goes to the left hand corner when I turn on the engraver. Also, images are engraved backwards! Any help will be appreciated.
https://lightburnsoftware.github.io/NewDocs/Troubleshooting-Output.html
Thank you very much that helped fix the orientation problem and printing backwards. My area that my laser uses in LightBurn is about half of my actual size I have, I have tried adjusting it in machine settings but it didn’t work. Does anyone know how to get my laser work area and Lightburn to line up together? If I can get that working I’m all set!
The work area setup in LightBurn is in the same page, Edit Device Settings
I have adjusted the setting you have shown with no luck. My laser has limit switches and it stops when told to move but the work area is still small compared to LightBurn area in the program. I have all my problems fixed except for the small work area compared to LightBurn work area. Any help would greatly be appreciated to fix this issue. I really want to buy and use LightBurn. Thanks in advance.
