Bonjour
Après avoir installer lightburn sur mon ordi il ne reconnaît mon orthur 2 pro SF et insiste avec une connexion Emblaser ?
Comment modifier la connexion ?
Hello After installing lightburn on my computer it does not recognize my orthor 2 pro SF and insists on an Emblaser connection? How to modify the connection?
Hello
Not sure where Emblaser would be coming from. I didn’t think that was a distinct device type. Are you able to select a different device type? It should be “GRBL”. If you cannot change device type then use manual setup to simply create your own.
